70 Users Online (69 Members):
Forums >> Community >> Newbies >> Material Pattern Alignment
5 Posts No Rating |
Greetings again all. trying to align a tile pattern with the top of a door in revit architecture 2011. I opened the materials editor/ click render appearance tab/ click on jpg image that I imported under "ceramic"/ click on transform/ click position/ change dimensions under offset until the tile pattern aligns with the top of the door in the model view. Looks good, so I hit render...and the tile pattern is unchanged...still in the original position in the rendered image (see attached images). Does anyone know how to fix this? Appriciate the help...
![4 Stars: 2 Votes](/images/stars_4.gif) |
Try going to the Texture Alignment... Button under the surface pattern for the material. This align's the surface pattern with the render pattern.
Need help with chainlink rendering/ chainling pattern alignment. |
Mon, Nov 9, 2009 at 11:48:43 AM
hatch pattern in material anomolies |
Fri, Aug 26, 2016 at 9:35:26 AM
Brick hatch course alignment |
Wed, Dec 2, 2015 at 4:37:53 PM
Where is pattern setting in material browser |
Thu, Jul 26, 2018 at 1:52:03 PM
curbed wall texture alignment |
Sat, Dec 1, 2012 at 5:47:58 AM
Members: | 2016934 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
