113 Users Online (111 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 2011 Lighting issue
Tue, Feb 15, 2011 at 10:50:27 AM | 2011 Lighting issue
leathamj
I am having lighting problems with my renderings when artificial lights are on.  The problems occured seemingly at random because renderings were going fine until one fine day they stopped working correctly.  When I render with the sun only, colors seem normal (it's just dim from lack of more windows), but when I turn artificial lights on, with or without the sun, the lights render crazy.  I am absolutely 100% positive that there is nothing obstructing and view or light sources.  I even add studio/omni lights in the middle of the room just for tests.  Any ideas?  I have attached a couple renderings, each example has a sun rendering and a artifical light rendering.  Please help
Tue, Feb 15, 2011 at 1:44:36 PM | 2011 Lighting issue
4 Stars: 203 Votes
Did you try to change some values in "Adjust Exposure" after rendering?
Tue, Feb 15, 2011 at 2:27:19 PM | 2011 Lighting issue
leathamj
yeah, unfortunately it's definately not an exposure issue
Interior/Exterior Lighting
Fri, Oct 8, 2010 at 12:53:06 PM
Render Internal Lighting Issue
Sun, Nov 7, 2010 at 8:04:48 PM
Lighting fixture problems
Wed, May 10, 2017 at 9:52:10 AM
13
interior lighting for exterior rendering [ 1 2 ]
Thu, Feb 11, 2016 at 2:03:05 PM
16
Revit 2011 Exterior Lighting
Fri, Nov 11, 2011 at 12:16:03 PM
11
Page generation time: 0.9476
