101 Users Online (100 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Schedule text erased when inserting new plan note
Tue, Feb 15, 2011 at 10:42:37 AM | Schedule text erased when inserting new plan note
markdstonerii
So, if I insert a new symbol (plan note, in this case), when I select it and edit the note to read, say, "1", the text already entered in the schedule under plan note #1 is deleted (though it's still available under the drop-down menu).  Does anyone know why this is/how to fix it?  It's incredibly aggravating.
FYI, I'm using Revit2011, though I had the same problem(s) in Revit09.
Thanks, AS ALWAYS, for your help.
mark
How do I combine fields in a note block with fields in a room schedule?!?
Thu, Mar 4, 2010 at 3:51:58 PM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Window and Door schedule with note blocks?
Tue, Jul 11, 2023 at 2:50:46 PM
Note Block / Schedule for General Construction Notes
Wed, Feb 25, 2009 at 10:45:50 AM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:51 AM
Page generation time: 1.4333
