104 Users Online (103 Members):
Forums >> Revit Systems >> Technical Support >> Autocad MEP duct work question
1 Posts No Rating |
Im trying to see if there is a way two do the following in ACAD MEP 2009. 1) When I draw flex duct, the size goes right in the middle of the hatching and becomes un-readable. Is there anyway to offset the size JUST on the flex duct (or) show a break in the flex duct. I know I can do it manualy but I want to do it permenantly if possible. 2) Is there anyway to put the name of the duct system on the rectangular duct only? Ie I want the ducts to say 24"x14"RA, but only on rectangular. Thanks
8 Posts No Rating |
I'm not sure about 2009(haven't used it in a while), but you may be able to click on the annotation and apply a leader and place the annotation anywhere you want. If you are annotating automatically, that may be the problem. You might want to disable that feature and annotate manually.
Exporting from Revit 2013 to Autocad MEP 2010 while retaining intelligent object |
Sat, Dec 7, 2013 at 12:08:38 AM
Revit MEP or AutoCad MEP |
Fri, Oct 14, 2011 at 8:21:49 AM
Duct won't tap to oval duct. |
Tue, Aug 22, 2017 at 12:38:49 AM
Duct Systems. |
Mon, Aug 5, 2013 at 7:48:16 AM
Eccentric Duct Fittings? |
Thu, Dec 15, 2011 at 10:58:31 AM
Members: | 2030567 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
