99 Users Online (98 Members):
Forums >> Revit Systems >> Technical Support >> plotting issues multiple sheet sizes
3 Posts No Rating |
has anyone had an issue with plotting from the same printer but using different sheet sizes? for example: revit can store all the information about print set-ups. we have an oce tds600 printer with 4 rolls. but when i set up a 24x36 print the windows system printer for the oce has to also be set to the same settings. but when i want to plot a half size set i have to go back to my windows settings for the oce and make sure the cut size and roll are correct and then plot again. but i cant go back to 24x36 without changing the windows plotter configuration again. with autocad the pc3 controlled it all. thanks for your help and insight
revit mep suite 2011 quad core, 8gb ram, 1gb video, 27" widescreen monitor mech/elec/plum/fp |
Setup PDF plotting in Revit |
Fri, Apr 15, 2011 at 1:06:51 PM
Problem Plotting Drawing Title Bubbles |
Thu, Nov 15, 2007 at 4:01:14 PM
Setting a project up to easily plot between different sheet sizes/plotters |
Sun, Jul 18, 2021 at 10:22:33 AM
Multiple independent sheet index for cover sheet |
Tue, Feb 4, 2014 at 8:28:13 AM
plotting / printing |
Wed, Feb 13, 2008 at 8:31:12 AM
Members: | 2017060 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
