61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Line tool shortcut when in a masking/filled region..
Sun, Feb 13, 2011 at 6:19:23 PM | Line tool shortcut when in a masking/filled region..
Blakey
Blakey Avatar
Hi,
Is there a way to initiate the line boundary tool when in sketch mode for a masking or filled region? I'm sure in previous versions I could get this to happen but have searched in 2011 to no avail.
 Thanks....
Mon, Feb 14, 2011 at 4:00:47 AM | Line tool shortcut when in a masking/filled region..
jonezy
i just type LI to initiate a line, however this may be different for you as i have a heavily customised keyboard shortcuts file... try it if thats what your after?
Line disappears under Masking/Filled Region
Mon, Jan 5, 2009 at 11:36:41 AM
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:25 AM
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:56 PM
Filled Regions Not Masking?
Tue, May 12, 2009 at 5:45:17 PM
Getting rid off masking regions?
Fri, Feb 4, 2011 at 4:12:57 AM
Page generation time: 2.0572
