48 Users Online (47 Members):
Forums >> Revit Structure >> Technical Support >> Can I have one detail on 2 sheets?
2 Posts No Rating |
Is there a way to paste one detail on two sheets? The main overall sheet and an SSK? I've been creating duplicates but this leaves a lot of room for error. Is there a simpler way? I just need to issue a sketch but hate making copies of the detail or plan just for the issue. Thanks!
Each sheet view must be unique (not including schedules and legends). Look into duplicate dependent views. Read about dependent views in your HELP.
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
Assuming the view is a drafting view, and you want it to be the same on each sheet... Make it into a group, and place an instance of the group into a new drafting view. If it is a live section... DUPLICATE AS DEPENDENT! Make sense?
Edited on: Tue, Feb 15, 2011 at 3:27:32 AM
2 Posts No Rating |
Thank You, this makes complete sense.
Typical Detail sheets on my first revit project |
Mon, Feb 8, 2010 at 9:22:07 AM
guide grids on sheets revit 2013 |
Mon, Aug 26, 2013 at 4:11:38 PM
My Section Detail and Numbers will not display on sheets. Can anyone tell me why |
Fri, May 21, 2010 at 5:09:18 PM
Using standardized detail sheets |
Tue, Apr 18, 2006 at 8:43:19 AM
Dummy Callout for 2017 |
Thu, Oct 4, 2018 at 8:48:19 AM
Members: | 2022352 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
