Forums >> Revit Structure >> Technical Support >> Reference Planes
![gregroberson Avatar](user_avatar/100163.jpg)
140 Posts No Rating |
Has anyone been succesful in easily creating macros for RST2011. I would like to do some very simple ones, but get confused just starting. I have done macros in a few programs, so was not expecting such confusion. I would like to create that can go into Visibility Graphics and make changes to my view. . .or multiple views. For example, hide reference planes, or show windows. That type of thing. Any thoughts? Greg
Use view templates.
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
To articulate WWHubs post a little further. You can set up the view to look how you want it to, save it as a new view template, and apply the template to multiple views. You can also use scope boxes to define the extents of reference planes, grids, levels, and so forth. So, if you have reference planes which you are only using for a foundation plan, you can create a scope box to capture those reference planes, so that they only appear within a certain bounding box.
I definately need to do more with our templates. . .lack there of. I will look into them more thoroughly. I apppreciate you guys comments as always. However, Have you all tried using macros at all. Are they fairly intuitive?
So far, I have not found any needs for macros so we don't use any. And, if you search the forums, you will only find a few questions regarding them but they may help you.
![coreed Avatar](user_avatar/14568.jpg)
" I definately need to do more with our templates. . .lack there of. I will look into them more thoroughly. I apppreciate you guys comments as always. However, Have you all tried using macros at all. Are they fairly intuitive? " Not Templates, View Templates
Edited on: Tue, Feb 8, 2011 at 11:16:44 AM
Listing the Abilities of Reference Planes |
Sun, Sep 9, 2012 at 9:24:07 PM
reference planes |
Wed, May 24, 2006 at 10:19:12 AM
Detail Lines and Reference Planes |
Tue, Sep 20, 2016 at 2:37:46 PM
reference planes |
Thu, Mar 26, 2009 at 3:14:10 PM
curved reference planes |
Fri, May 19, 2006 at 9:20:35 AM
Members: | 2022277 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
