82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Tips & Tricks >> Getting Annonation symbols to show up in plan for face based families
Tue, Feb 8, 2011 at 8:57:00 AM | Getting Annonation symbols to show up in plan for face based families
DeifyMe
4 Stars: 2 Votes
I've finally sorted this issue out, maybe someone has already posted this but I couldn't find it. I've been creating a number of faced based families to be used by our Mechanical engineer but could not get the symbols to show up in plan. The solution was so simple. The family I've been working on is a simple exit sign that the mechanical can use in his drawings but I can also use in my architectural model that renders properly as a light source. I had the model categorized as a Lighting Fixture which is the only option in REVIT Architect. However this morning I was working on the family in REVIT MEP and realized that more categories are available. I changed the category to Lighting Devices and then below noticed a new option box "Maintain Annotation Orientation". Check that box to yes and everything works great!
Fri, Jul 1, 2011 at 2:10:28 PM | Getting Annonation symbols to show up in plan for face based families
chuckbradley
This might work for displaying the fixture in the architectural model, but for a real electrical MEP project, this will not work.  Lighting devices are switches and things like that.  Lighting fixtures are lights that are supposed to show up in the lighting fixture schedule.  As a device, they will not.
I've found that for face based lighting fixtures, you have to use "detail items".  These are a lot like generic annotations, but are actually very different.  Annotations will resize appropriatly depending on the scale of the view.  Detail items do not scale automatically at all.  This is very uselfull for some lights like grid troffers that will stay a 2x4 or 1x4, but for the most part, this is no good, unless you make a detail item for each scale you might use and create yes/no parameters to control them.  That's how I do it anyway.
Fri, Jun 3, 2016 at 1:19:03 PM | Getting Annonation symbols to show up in plan for face based families
slhill
Thank you for posting your solution ... I wish that option was available for more than just the MEP "devices".  I ended up assigning my hose cabinet to "sprinklers" so I could use the embeded label.  ~shrug~
Plan annotations for face based families
Tue, Feb 8, 2011 at 8:59:45 AM
Scheduling Problem with Face Base Families
Tue, Jul 15, 2014 at 8:59:16 AM
Converting Ceiling Based families to Face Based Families
Tue, Jun 12, 2018 at 7:13:41 PM
Can't place face-based family on roof in Plan view (but can in 3-D?)
Tue, Oct 8, 2013 at 2:02:58 PM
How would you modify a family from face-based or hosted to one that is not?
Mon, Sep 26, 2011 at 8:39:50 AM
Page generation time: 3.4056
