43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> Component rotate
Mon, Feb 7, 2011 at 3:29:07 PM | Component rotate
Shnail
Some components can be rotated by selecting them, and then hitting the space bar, or rotating by selecting the rotate button. It would be helpful if there was a rotate option when the component is selected. For instance, highlighting a toilet brings up the little arrows which can flip the toilet 180 degrees. Adding a rotate arrow so that instead of highlighting the toilet then going up to the menu bar, and selecting the rotate function, one could just click on the rotate arrow on the toilet and rotate it.
Thanks
Revit user since 2008.
Mon, Feb 7, 2011 at 4:34:53 PM | Component rotate
TKennedy
4 Stars: 7 Votes
Spacebar can rotate components, but unfortunately (or fortunately, depending on what you prefer I suppose) when you have the flip arrows the spacebar controls those instead of rotating.
Tue, Feb 8, 2011 at 10:55:47 AM | Component rotate
Shnail
Right. I usually will use the spacebar to rotate a component as i place them into the drawing. But if there is a change to which way the toilet is facing, it would be nice to have a rotate arrow showing, like the flip arrows. As when hitting the spacebar it only flips the toilet, not rotate it 90 degrees.
Content hatch - rotate with component
Mon, Apr 11, 2011 at 10:22:42 PM
How to rotate a familly and have its texture rotate with it ?
Thu, Jul 19, 2012 at 1:00:20 PM
Materials
Thu, Dec 8, 2005 at 11:21:19 AM
2d Line Based compnents - rotate hatch region for plan and section
Tue, Jan 31, 2012 at 9:28:28 AM
ROTATE ELEMENT
Mon, May 16, 2011 at 8:15:09 AM
Page generation time: 0.6213
