96 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Cannot Draw Fittings with Filter Name
Sat, Feb 5, 2011 at 12:54:07 PM | Cannot Draw Fittings with Filter Name
bxuser
Hello to all
Using Revit MEP 2011.
I'm trying to layout a plumbing system without connecting to the fixtures, which means
no "connectors". I just want to layout the system as a schematic drawing. I can draw my "vent"
piping, having setting it up as a filter name. However, when I draw any fitting, it will not take on
the name "vent" when I hover over it. How do I get my pipes and fittings to have the name I assign
them to.
Thanks for your help.
Sat, Feb 5, 2011 at 6:06:57 PM | Cannot Draw Fittings with Filter Name
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
How are you filtering these?
What is the criteria assigned to the filter?
You really should be connecting them and assigning them to a system to keep them off the default system.
This will make filtering and modifying them a lot easier.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Sun, Feb 6, 2011 at 11:48:34 AM | Cannot Draw Fittings with Filter Name
bxuser
My pipe is a vent pipe. however, the elbow defaults to std. pvc.
I want my elbow to be vent pipe also.
Thanks
Stumped on why window selection or crossing selection wont pick pipe fittings ?
Sat, Jun 1, 2024 at 1:44:17 PM
help with a Filter issue in VG
Wed, Oct 21, 2009 at 11:05:42 AM
Duct Fittings showing halftone
Thu, Aug 11, 2022 at 1:49:21 AM
18" (450mm) storm piping & related fittings
Fri, Apr 17, 2009 at 5:16:02 PM
exporting revit to cad issue- duct and pipe fittings converted as blocks
Wed, Jun 17, 2015 at 1:58:56 PM
Page generation time: 0.6027
