41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Getting rid off masking regions?
Fri, Feb 4, 2011 at 3:32:27 AM | Getting rid off masking regions?
Dafpfy
3.5 Stars: 11 Votes
I dont realy understand why there are masking regions when you can make a white filled region.
you cant even change a masking region into a filled region,
am i missing something or is a masking region just a white filled region?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, Feb 4, 2011 at 4:12:56 AM | Getting rid off masking regions?
4 Stars: 201 Votes
Directly from your HELP
Masking Regions
Masking regions provide a way to obscure elements in a view. Masking regions may be useful in scenarios like the following:
  • You need to obscure elements in a project.
  • You are creating a detail family or a model family and need the background of the element to mask the model and other detail components when it is loaded into a project.
  • You need to create a model family (from imported 2D DWG files) that obscures other elements when placed in a view.
You can create 2D and 3D masking regions. 2D masking regions can be created in a project and in the Family Editor when you are creating a 2D family (annotation, detail, or title block). 3D masking regions can be created in the Family Editor when you are creating a model family.
Masking regions do not participate in shading; they are always drawn the background color of the drawing area. Masking regions cannot be applied to element subcategories.
Filled Region
The Filled Region tool creates a 2-dimensional, view-specific graphic with a boundary line style and fill pattern within the closed boundary. The filled region is parallel to the view’s sketch plane. The tool is useful for defining a filled area in a detail view or for adding a filled region to an annotation family.
Filled regions contain a fill pattern. Fill patterns are of 2 types: Drafting or Model. Drafting fill patterns are based on the scale of the view. Model fill patterns are based on the actual dimensions in the building model.
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Exporting to Autocad with Masking Regions
Thu, Apr 25, 2013 at 10:33:27 AM
11
Revit 2010 Masking Regions
Mon, Nov 30, 2009 at 4:42:34 PM
Masking Regions not "masking"
Mon, Dec 14, 2009 at 11:21:22 PM
masking regions
Mon, May 11, 2009 at 4:31:49 PM
Page generation time: 0.7974
