138 Users Online (136 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Keynote Data problem
Wed, Feb 2, 2011 at 1:56:42 PM | Keynote Data problem
sandh01
3.5 Stars: 2 Votes
Hi guys,
I'm trying to learn how to use the keynote function in Revit Architecture 2011, but I get a warning coming up saying;
"Unable to load keynote data; the file has either been moved or deleted.  Check the folder location of the keynote table in the keynoting settings and change the folder path if necessary."
I am not sure what this is asking me to do, I don't have 'keynote settings' or a 'keynote table' and I have reloaded the keynote annotation family.  I have searched revit help and the net with no useful information.
Any help is greatly appreciated
Wed, Feb 2, 2011 at 2:21:49 PM | Keynote Data problem
Simple - Revit can't find your keynote file.  From the annotate tab, click on the tag down-arrow then keynote settings.  Now browse for the full path of your keynote file, then set your path type and numbering method then OK.  Now REvit can find them.
BTW - If you search keynot in your HELP - you will find everything you need - including Keynote Settings.... It's all there if you look.
Edited on: Wed, Feb 2, 2011 at 2:24:42 PM
Wed, Feb 2, 2011 at 2:35:58 PM | Keynote Data problem
sandh01
3.5 Stars: 2 Votes
Aha! Thank you.
I found the tutorials for using the keynotes, just that first warning was throwing me off.  Thanks again.
Unable to Load Keynote Data in A360 project
Thu, Mar 3, 2016 at 10:33:05 AM
Keynote Data
Sat, Aug 23, 2008 at 10:06:26 AM
Material Keynote not working on window family
Tue, Nov 26, 2013 at 3:47:40 PM
keynote categories
Fri, Aug 10, 2012 at 3:56:23 PM
Multiline keynote
Thu, Jan 8, 2009 at 2:31:33 PM
Page generation time: 1.3553
