61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Slanted column
I'm sorry if this has already been covered before, but how can you making a column on the angle. If some one does reply, can you keep it basic as I've just started with Revit. Thanks
Macca Sunshine Coast QLD Australia |
Use can use "Create" in Modeling mode to make a "Solid Blend" in the project or if you want to create a column that you can use again and again you will want to make it a family by going to "File" - "New" - "Family" - go to imperial or metric templates - "Columns.rft" and create it as a family, again with the Solid Blend. You can use dimensions as parameters in the family to control base size, top size, slant offset, etc.
Here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=592#2062
thanks for the quick reply. I'll see how I travel. Puzzle
Slanted Columns in Revit LT ?? |
Wed, Mar 13, 2013 at 8:28:19 AM
Mirroring a slanted column |
Mon, Mar 10, 2014 at 7:50:04 PM
Can't mirror L Angle slanted column |
Mon, Apr 11, 2011 at 9:52:21 AM
Trim on slanted column |
Mon, Sep 8, 2008 at 1:20:01 PM
slanted model in place column |
Sun, Nov 7, 2010 at 9:01:37 PM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
