Forums >> Revit Building >> Technical Support >> Text Notes Paragraph Formatting (numbered)
36 Posts No Rating |
I've figured out how to Automatically number my text notes using the paragraph format feature, but if I try and leave a blank space between each numbered item, Revit numbers the blank line. Does any one know a way to allow a blank line between numbered items?
Autodesk Revit MEP 2015 |
I just ran into this problem myself. It's best to put all the lines in you need, then go to the line you want blank, go to the format button and pick "no format". Now this works great for bullets, I'm not sure if they will update correctly if they are numerically or letter formatted.
Just an update, I tried it and it does not work with numbers and letters. I would say your best bet is to do what you want in Word and then copy and paste it in.
Old post, a late reply, but for those who want to know.I use revit note block to make a numbered text block, a note block is a simple kind of schedule that is used to list Annotation symbols in the schedule, so create an empty symbol (or a small circle symbol) and place it in your project, i place the symbol in the bottom of the first sheet where i put legends and General instructions, The number of instances placed of that symbol element determin the maximum number of notes you can add to the schedule (Note block) since the note block is going to schedule that empty symbol entities.
Next create a note block and choose that empty symbol to be scheduled.
Next, add 2 parameters , and change their type to be instance and let it become text field. One parameter will be the number place holder, the other parameter will be the Note place holder, once done, you can populate the schedule any way you want.
I realize this is an old post, but it was the first to pop up on a google search. In 2017, SHIFT+Enter will put a line without numbering it. Just posting this here for more visability (hopefully)
Oh wow, thank you! Shift+Enter! This is what I was looking for.
shift + enter is not working for me. as soon I leave the text box editor, the number appears... or it doesn't appear and then the next line starts from 1 or A
5 Posts No Rating |
I have exactly the same problem @glavoc is having above. Of course, Autodesk's help is less than useless as always, because the Shift + Enter is what they say to do.
Edited on: Thu, May 17, 2018 at 9:18:06 AM
Pressing Shift + Enter only works with Revit 2017 and up as they updated the text editor significantly in those releases.
Text Formatting |
Thu, Oct 25, 2007 at 11:12:29 AM
Why does Revit text / formatting suck so BAD!?!?! |
Tue, Sep 6, 2016 at 11:14:27 AM
Text formatting (bullets & indents) |
Wed, Jun 11, 2008 at 8:49:15 PM
formatting a numbered list for multiple columns |
Thu, Jun 12, 2014 at 9:38:49 AM
Text Field |
Mon, Feb 1, 2010 at 6:04:12 PM
Members: | 2098622 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
