86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> how to add elevation to curb sweeps?
Tue, Feb 1, 2011 at 9:07:40 AM | how to add elevation to curb sweeps?
treshernandez
I'm creating a contoured site and need to attach a curb sweep to follow the different terrain. What's the best way to go about this?
Thanks, Tres
Tue, Feb 1, 2011 at 1:52:30 PM | how to add elevation to curb sweeps?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Check out this URL, http://tinyurl.com/349j4n5 this is a program add on called Site Works for revit, seems pretty cool although rather expensive. The method attached is one that I developed which gets pretty good results. But takes a lot of effort. If you are modeling flat ground, which there is not much of, you can split the topo and lower a portion. This is ok if it is just for rendering or something like that no good for construction docs.
Fri, Feb 4, 2011 at 2:53:51 PM | how to add elevation to curb sweeps?
treshernandez
Thank you for your help. My firm purchased a license of Eagle Point Siteworks for Revit and with its first release comes great learning curves and incompatibilities. So, we're steering in a more creative approach. Thank you for the attatchment and I look forward to trying this method. It's all about learning a different way to do things.
Fri, Feb 4, 2011 at 3:54:40 PM | how to add elevation to curb sweeps?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
It is about learning a different way to do things and with all this Revit stuff the learning curve is steep. good luck.
Lifting up building for curb
Sun, Dec 30, 2007 at 1:21:28 PM
Curb & Sidewalk Sweeps that could be attached to site topo edges! Why not?
Wed, Apr 19, 2006 at 9:17:07 AM
How do I make curb
Wed, Dec 14, 2011 at 3:57:42 PM
Sloped Sweeps
Tue, Jun 17, 2008 at 6:24:32 PM
How to do a road curb that follow a sloped roadway?
Mon, Aug 12, 2013 at 1:34:06 AM
Page generation time: 0.7697
