Forums >> Revit Structure >> Tips & Tricks >> Historic Beam Shape Family for Revit Structural
Mon, Jan 31, 2011 at 10:02:18 AM | Historic Beam Shape Family for Revit Structural
drsweeney
I am being asked by a client to build an existing facility in Revit.  The building was constructed in the 1950's and does not use the currently published AISC steel shapes (they use the WF designation).  Although some are similar to the current shapes, not all are.
 Has anyone found a beam family for these historc shapes?  Or can suggest where I might find them>
Thanks
Mon, Jan 31, 2011 at 12:25:02 PM | Historic Beam Shape Family for Revit Structural
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I think you will have to make those that you can not model with the newer shapes.
Tue, Feb 15, 2011 at 9:11:00 AM | Historic Beam Shape Family for Revit Structural
emgeeo
3.5 Stars: 7 Votes
have you looked at autodesk seek?
you could also create the sizes yourself.  each family has a .txt file associated with it, which can be imported into excel, and exported back out.  you could use excel to build this family of historic sizes.
make sense?
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:43 PM
structural beam system visibility
Fri, Jun 27, 2008 at 12:24:51 PM
Steel beam connection with structural wall
Fri, Mar 1, 2013 at 9:06:41 AM
Created Family Beam Parameters
Wed, Jan 12, 2011 at 1:49:38 PM
Revit Beam for Reinforced Concete works
Sun, Jun 15, 2008 at 1:05:31 PM
Page generation time: 2.0521
