130 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Move room area to other level
Sun, Jan 23, 2011 at 7:13:44 AM | Move room area to other level
brjdk
Hi
I'm sketching on a project that have several levels with different kinds of functions described by room areas / tags and grouped by departments. I have setup all departments in schedules and given them numbers.
Now, as it often happens in this sketching phase, functions has to move to other locations, on other levels. This is where I get some troubbles.
How can I move a 'room area' to a other level without having to rewrite the room numbers ?
If I just cut and paste the area it gets a new number :-/
I hope some have had this issue and found a solution :-)
Thanks
Sun, Jan 23, 2011 at 9:02:07 AM | Move room area to other level
Revit will always assign a new room number - but no problem, just change it.
Sun, Jan 23, 2011 at 10:45:19 AM | Move room area to other level
brjdk
Hi wwhub
Not the answer I hoped for :-/
The problem is, that departments consists of lot of rooms, more than 20, and it's a lot of renumbering :-(
But thanks, I now know that there is no other way
Thanks
Mon, Jan 24, 2011 at 1:03:55 PM | Move room area to other level
Bimman
Bimman Avatar
1 Stars: 2 Votes
if you have alot to change, i have found it is quicker to change them from a room schedule rather than from the plan view.
PWD
move Room Tag to different level
Thu, Sep 18, 2014 at 11:21:09 PM
Room schedule - area
Tue, Nov 9, 2010 at 1:07:43 PM
room area calculation
Thu, Jan 15, 2009 at 5:51:20 AM
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:26 PM
Level parameter problem in tags
Sat, Jul 21, 2018 at 6:13:21 AM
Page generation time: 1.0564
