Forums >> Revit Building >> Technical Support >> Selecting-De-selecting objects.
I am fairly new with Revit.
I would like to find out if there is a way to filter the exterior walls from the interior walls when you pick all. I am trying to copy all interiror walls from a level with the exception of the exterior walls that go all the way to the roof. and I do not want to go one by one.
Thanks.
Select the interior walls in elevation.
If all the external walls continue over multiple levels, when you drag a window over the level in question and filter walls the exterior walls will not get selected as they are not full contained within your window.
As with ACAD dragging your window in different directions results in different effects of selection.
HTH.
Thanks Mr Spot.
What I need is as follows: I want to copy doors, windows, dimensions and interior walls from level 2 to level three. While selecting the elements, by mistake I pick an undesired object that highlights immediatelly, how I can de-select the unwanted Item (ie; exterior walls) when it is not specified in the filtering list?
Ctrl-click is add
Shift-Click is remove.
HTH.
1 Posts No Rating |
select an interior wall, rt click and select all instances...........I believe this command is level specific.
Select all instances is a global command - it does exactly what it says.
Thank you Mr. Spot. It worked the way I wanted it
Revit moves objects just by selecting them????? |
Wed, Jul 17, 2013 at 11:53:35 AM
Selecting Objects on floor below |
Thu, Nov 29, 2012 at 2:54:56 PM
Highlight when selecting |
Wed, Jun 29, 2011 at 4:05:29 PM
Selecting objects from a list? |
Mon, Aug 15, 2005 at 2:29:27 PM
Weird behavior when selecting objects |
Tue, Nov 27, 2012 at 9:25:25 AM
Members: | 2114612 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
