80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Scheduling Coordinate Points for Complex Geometry
Thu, Jan 20, 2011 at 5:58:31 PM | Scheduling Coordinate Points for Complex Geometry
kcdyer13
Hello All,
 I am trying to efficiently document complex exterior wall geometry.  I was hoping to use spot coordinates that could show the X,Y,Z components from a set 0,0.  Then, be able to set up the X,Y,Z components in a schedule which will have to be exported to Excel.  Any suggestions?  Has anyone used the Excitech tool for Revit 2011?  Any help would be greatly appreciated!
Fri, Jan 21, 2011 at 10:17:04 AM | Scheduling Coordinate Points for Complex Geometry
Check out the extensions availble with your subscription .  I thik this is the one you are looking for:
http://www.extensions4revit.com/n/e4r/856/60
Then by using a family that will schedule using this extension - you got it.  That family might be just a point?
Fri, Jan 21, 2011 at 10:46:23 AM | Scheduling Coordinate Points for Complex Geometry
kcdyer13
Thanks, WWHub!
I am looking for something that would read the coordinates without manual input, do you know if this might do that?  I will research this extension a little further, too.
Thanks again...
Creating Complex geometry
Wed, Nov 16, 2005 at 2:59:36 AM
Scheduling Topographic points
Mon, Sep 28, 2009 at 7:52:44 PM
Families - Locking complex geometry
Thu, Dec 4, 2014 at 10:48:23 AM
Mass Geometry Flaw | Circle points
Fri, Dec 4, 2015 at 4:04:47 PM
Allow 3 point Definition for Reference Planes
Mon, Mar 28, 2005 at 8:53:53 PM
Page generation time: 0.9210
