Forums >> Revit Building >> Technical Support >> Curved Angled Glass Walls
Hey everyone, I am currently having MAJOR problems with creating curved angled glass walls. I have to build 15 walls which are angled to the same degree as my columns. I have tried creating masses, which I finally managed to.. only to have Revit tell me that I cannot use the mass to create a glass wall, even though I managed with one already. I have attached some images of the building, if anyone has any suggestions as to how I can put the walls in they would be greatly appreciated. Thanks, Nick
12 Posts No Rating |
WHAT METHOD DID YOU USE TO CREATE YOUR MASS, EXTRUSION, SWEEP ETC...?
Gabriel Flores AAS/CDD, BS/CM |
Did you create the "Mass" then create a "Curtain System" by face?
Hey there, That's right, you use a curtain system, instead of trying to apply a curtain -wall- by face. If you don't want to use massing, you can build a swept blend in the generic model category, and then hide it. attached is a picture of a curtain system applied to a swept blend face. You may need to make a new curtain system type, the default is 5x10 panels.
Edited on: Thu, Jan 20, 2011 at 1:24:24 PM
Thanks, I managed to align a level to the top of each of the columns so that I could make masses that go all the way to the underside of the roof. Apparently the method I was using before wasn't working... But I can now create the masses and create curtain wall system from face... Thanks!!
curved angled curtain walling |
Wed, Mar 8, 2006 at 4:18:51 AM
Angled Walls in Revit |
Mon, Jan 12, 2015 at 8:48:27 AM
Making Angled or canted walls |
Tue, Jun 3, 2008 at 2:10:08 PM
angled corner joint - how to lock angled corners |
Thu, Jul 18, 2013 at 5:10:12 AM
11
Revit 2011-putting openings in angled walls. |
Sat, Sep 10, 2011 at 5:45:28 AM
Members: | 2100571 | Objects: | 23171 | Forum Posts: | 152294 | Job Listings: | 3 |
