72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> Macro Manager does not like code
Wed, Jan 19, 2011 at 10:53:22 AM | Macro Manager does not like code
davidr
Below i have included some code that i wrote that basically just draws a line on a plot sheet.  It's a test run for another macro that i am trying to code.  When i save it with F5 (debugger) nothing comes up and it seems ok.  When i get out and try to Run it with Macro Manager, the Run button is deactivated.  I know it does not like something in the code but I don't know what??  I am running 2011 on windows xp pro 64.  Any ideas would be appreciated.
Partial code:
using Autodesk.Revit.DB;using Autodesk.Revit.UI;using Autodesk.Revit.Creation;
using XYZ = Autodesk.Revit.Geometry.XYZ;using LINE = Autodesk.Revit.Geometry.Line;                        UIAPPLICATION app = m_doc.Application;                        //declare variables                        double x1 = (5.0);                        double y1 = (5.0);                        double z =  (0.0);                        double x2 = (7.0);                        double y2 = (5.0);                                               //create object                        XYZ point1 = app.Application.Create.NewXYZ(x1, y1, z);   //takes doubles                        XYZ point2 = app.Application.Create.NewXYZ(x2, y2, z);                        //Create Line                        LINE line = app.Application.Create.NewLineBound(point1, point2);
Wed, Jan 19, 2011 at 10:58:48 AM | Macro Manager does not like code
davidr
sorry about the formatting
lets hope this works:
using XYZ = Autodesk.Revit.Geometry.XYZ;using LINE = Autodesk.Revit.Geometry.Line;UIAPPLICATION app = m_doc.Application;//declare variablesdouble x1 = (5.0);double y1 = (5.0);double z =  (0.0);double x2 = (7.0);double y2 = (5.0);  //create objectXYZ point1 = app.Application.Create.NewXYZ(x1, y1, z);   //takes doublesXYZ point2 = app.Application.Create.NewXYZ(x2, y2, z);//Create LineLINE line = app.Application.Create.NewLineBound(point1, point2);
Wed, Jan 19, 2011 at 11:01:59 AM | Macro Manager does not like code
davidr
ok..so i have attached a file with the code in it-happy trails
Sat, Mar 12, 2011 at 10:36:04 PM | Macro Manager does not like code
paulh
The code doesn't look properly formatted to me. Does it compile without errors?
Tue, Mar 15, 2011 at 1:24:54 PM | Macro Manager does not like code
davidr
no it doesn't thats the wierd thing about it...
Trying to figure out how to code using VB.NET in Macro Manager and I need HELP!!
Fri, Mar 28, 2014 at 8:16:28 PM
Need help with Macro program for point cloud visibility
Tue, Apr 25, 2017 at 4:07:38 PM
Cannot grab elements in 2011 using 2010 code
Mon, Jun 21, 2010 at 5:40:27 PM
Macro request
Mon, Jul 19, 2010 at 10:35:00 AM
Things necessary for a Good BIM Leader / Manager
Mon, Feb 22, 2010 at 8:14:39 AM
Page generation time: 0.2300
