97 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Cutian Wall Horizintal Mullion Spacing
Wed, Jan 19, 2011 at 9:01:42 AM | Cutian Wall Horizintal Mullion Spacing
ouppal
I am working on a high rise building. I am using a lot of curtain wall and every floor has different horizontal mullion spacing’s. Is there a way of setting the distance of mullions (not equally) so I do not have to go back into elevation or 3D view and manually change the spacing?(500mm, 1100mm, 2000mm etc etc) I have tried to make the changes to 1 panel so I can try the match properties option but it doesn't work. Any help would be greatly appreciated.
Wed, Jan 19, 2011 at 9:05:20 AM | Cutian Wall Horizintal Mullion Spacing
From your question, I think you need to spend some time understanding curtain walls.  Here is a good place to learn some of this:  http://revittotd.com/06/225 You will find a whole sequence on curtain walls that will help you there.
If your curtail wall goes full building height as it should, you will have to manually move the grids.  If it is floor to floor, you can set up an automatic curtain wall with muillion spacing.  But I thick the manual metod is easier.
Wed, Jan 19, 2011 at 10:51:32 AM | Cutian Wall Horizintal Mullion Spacing
ouppal
Thank you for the link, unfortunately it was basic curtain wall information which I know. In my model I have a few different curtain wall instances. Some span multiple floors and others span 1 floor. I was hoping for some sort of parameter setting that would allow me to set and control the different mullion heights (not equal to each other) within an elements or type window.
mullion join at angled mullion 2017
Sat, Oct 21, 2017 at 11:53:55 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing
Mon, Jan 19, 2015 at 7:41:37 AM
mullion spacing
Fri, Mar 16, 2007 at 6:05:49 PM
Curtain Wall Maximum Spacing
Wed, Jul 18, 2012 at 2:14:41 PM
parametric mullion
Thu, Feb 26, 2009 at 11:57:57 AM
Page generation time: 2.0670
