39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> help! how to create a sectional perspective??
Thu, Nov 3, 2005 at 8:18:18 PM | help! how to create a sectional perspective??
devil13
hi could any kind soul out there tell mi how to create a sectional perspective to show services in the ceiling in 3D using camera views or is there another better way? thanks alot!
Thu, Nov 3, 2005 at 10:01:56 PM | RE: help! how to create a sectional perspective??
hutana
HI I use dynamic view to create sectional perspectives Assume you have created a standard section as usual. 1. Go to 3D view of your building 2. Save as duplicate called say Section 1 perspective 3. Call up Dynamic View (FShadey 4. Hit far right arrow 5. Click on "Orientate to a "view" 6.Look for your Section and click on it This will bring up your section in Perspective (elevation). Note: Remember to set your depth of field as desired in your plan to control what you want to be seen. And you can set your sectional cut to appear in a nice red with some settings in the VP. Hope it helps Cheers Steve (4 yrs on Revit and still learning everyday) That means I'm dense or this prog is deep.???)
Fri, Nov 4, 2005 at 1:54:31 AM | RE: help! how to create a sectional perspective??
devil13
hi hutana, thanks alot for your reply and help! appreciate it alot! the method you taught mi helped mi to get the sectional elevation but how about getting a 3D sectional perspective with a diminishing point? and definately i think this program is deep.... Post edited on 2005-11-04 02:00:11
Fri, Nov 4, 2005 at 11:26:07 AM | RE: help! how to create a sectional perspective??
JAIMERIOSJR
Hi, I am new using Revit, however, what you can do is to create the 3D (Axonometric) view and adjust it the way you want, then you may use the "hide command" (on the bottom (eye glasses)) to remove all the elements that are on the way of the desired view such as wall, windows, etc. I have tried twice and it has worked to me. Or you can use the "View>New>camera" command, generate the view you want then you can use the "Hide command" as explained before. Hope it works... Post edited on 2005-11-04 11:30:25
Fri, Nov 4, 2005 at 4:37:01 PM | RE: help! how to create a sectional perspective??
moneos
Create camera/perspective 3D view and activate "section box" option in View Proprieties. Rotate, scale section box as you like. Use F8/view controls to adjust the view
Fri, Nov 4, 2005 at 5:10:06 PM | RE:
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
JAIMERIOSJR - 2005-11-04 11:26:07]Hi, I am new using Revit, however, what you can do is to create the 3D (Axonometric) view and adjust it the way you want, then you may use the "hide command" (on the bottom (eye glasses)) to remove all the elements that are on the way of the desired view such as wall, windows, etc. I have tried twice and it has worked to me.
Hope it works...
The Hide command is a temporary hide. When you close the view you will lose your settings. Hidden objects will also still print. The tool is used to aid in building the model and not for creating views that will be used in documentation.
The scope box is the correct method.
Post edited on 2005-11-04 17:10:36
Post edited on 2005-11-04 17:11:00
Post edited on 2005-11-04 17:11:18
Fri, Nov 4, 2005 at 8:35:53 PM | RE: help! how to create a sectional perspective??
JAIMERIOSJR
thank you for the clarification.
Fri, Nov 4, 2005 at 10:12:55 PM | RE: help! how to create a sectional perspective??
devil13
hi thanks all revit user in helping! however the scope box is hard to control especially the rotating part.... how can i make it easier? like when i try to rotate, the image became distorted. and someone talked about the scaling of the 3D model after placing the camera, how can i scale it?
Sat, Nov 5, 2005 at 12:51:07 AM | RE: help! how to create a sectional perspective??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Why would you want to rotate a sectional perspective? They are used a presentation drawings. If you want to use it for modelling just create a sectional isometric view as outlined previously. The views can be scaled once placed on a sheet. Select the view and in the top bar you'll see a size come up, select this and then change the scale as required. If its an isometric just change the scale of the actual view, 1:100, 1:50 etc.. HTH.
Sat, Nov 5, 2005 at 1:57:36 AM | RE: help! how to create a sectional perspective??
devil13
oh as i said earlier i wanted to capture a view from the 3D perspective at a good position and angle so that it show enough depth for mi to show the ceiling services running through a couple of rooms....however i couldnt get to that due to what i mentioned earlier, its either the angle is not right or it doesnt have the correct depth ( as in the dimishing point not far enough) so i need to do some adjustment and i had difficulties getting it correct.
Mon, Nov 7, 2005 at 6:20:09 AM | RE: help! how to create a sectional perspective??
moneos
This is what I've got using method described before in my previous post. Picture done with Revit and Photoshop.
Tue, Feb 7, 2006 at 5:11:11 PM | RE: help! how to create a sectional perspective??
zaklee
On the topic of scale, it has been discovered that the scale factor for isometric drawings is incorrect in Revit 8.1. I think it's also wrong in version 8. To correct the problem, you should set a custom scale for the view. The scale factor should be the intended scale factor divided by 1.225. You'll have to round off as the dialog only accepts whole numbers (integers). As an example, if you intend to have an isometric at a scale of 1/4" = 1'-0" (1:4Shadey you would create a custom scale of 1:39 (48/1.225 = 39.18 (~39)). 1/8" would be 1Blushing8. Happy scaling.
Tue, Nov 22, 2016 at 7:12:43 AM | help! how to create a sectional perspective??
#13
Dramos258
1. Go to a floor plan and make sure the crop view is set far back so that you can place the camera away from the building
2. Take your camera and place where you would like to see the view
3. On the view cube, right click and orientate to whichever section you have created to view
4. On the vie cube click the top view arrow
5. On the properties tab, check the section box so that its on
6. From there you can adjust the section box so that it cuts through where you want it
7. Align the view again as mentioned in point 3
8. Use the wheel to pan and zoom as needed
NOTE: Do not turn off the section box in the properties tab as this will reset everything, just hide it
sectional perspective TO SCALE
Wed, Feb 11, 2009 at 3:14:30 PM
Sectional Perspective NOT cutting in the N,S,E and W direction
Mon, Oct 3, 2011 at 2:29:47 PM
Sectional perspective with lighting question
Tue, Nov 23, 2010 at 9:08:07 PM
Rendered Sectional Perspective Cut
Tue, Jan 25, 2011 at 7:25:54 AM
3D Section view
Wed, Apr 18, 2007 at 10:33:35 AM
Page generation time: 1.7666
