77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dimensions in feet and meters
Mon, Jan 17, 2011 at 2:20:26 AM | Dimensions in feet and meters
RNLRNL
I have a client who wants to see building dimensions in feet and centimeters and areas in feet and meters. Is there is simple optioon or was of doing this in Revit? I am using Revit 2011?
Thanks
Mon, Jan 17, 2011 at 1:51:10 PM | Dimensions in feet and meters
You can use two dimension styles, one metric and one english, then add both dimensions.
Tue, Jan 18, 2011 at 3:13:18 AM | Dimensions in feet and meters
RNLRNL
Thanks.
 What about for shoowing the room areas in both meters and feet - is there a similar solution?
Tue, Jan 18, 2011 at 7:45:32 AM | Dimensions in feet and meters
Edit your room tag and look at the unit options under the area portion of the tag.
Level Display (only) to decimal feet
Sun, Aug 10, 2014 at 11:00:02 PM
12
Revit 2014 - Need to eliminate zero feet in dimensions
Thu, Apr 3, 2014 at 1:07:02 PM
Feet per second squared error? What?? [ 1 2 ]
Wed, Feb 20, 2013 at 2:26:23 AM
18
Toposurface Contours
Mon, Aug 25, 2008 at 4:47:23 PM
Face to face wall dimensions
Mon, Jul 11, 2011 at 11:13:35 AM
Page generation time: 1.8482
