80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Set an interior wall's centerline distance from the exterior face of building?
Sat, Jan 15, 2011 at 6:14:16 PM | Set an interior wall's centerline distance from the exterior face of building?
GeneLaratonda
GeneLaratonda Avatar
How do you set an interior wall's centerline distance from the exterior face of building?
 I have tons of newbie questions,but the answers are coming slow.
Edited on: Sat, Jan 15, 2011 at 6:14:46 PM
Sat, Jan 15, 2011 at 6:41:08 PM | Set an interior wall's centerline distance from the exterior face of building?
GeneLaratonda
Figured it out.
1. Click on the interior wall you want to move
2a. If a dimension is from centerline of interior wall to centerline of exterior wall, then just click the witness line grab point till it moves to the exterior face
2b.  If a dimension appears in relation to some other object, just click the witness line grab point and drag it to the exterior wall and then do step 2a.
2c.  If the dimension does not drag past another wall to get to the exterior wall you must click the witness line grab point when it rests on the intersecting wall till get gets to the face closest to the exterior wall and then do step 2b.
Yeah, confusing. I thought so too.
Edited on: Sat, Jan 15, 2011 at 9:22:32 PM
Edited on: Sat, Jan 15, 2011 at 9:24:12 PM
Sun, Jan 16, 2011 at 12:55:48 PM | Set an interior wall's centerline distance from the exterior face of building?
coreed
coreed Avatar
4 Stars: 16 Votes
click attached file
Edited on: Sun, Jan 16, 2011 at 12:57:08 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Lighting fixtures not against exterior wall face
Mon, Sep 8, 2008 at 1:24:10 PM
exterior to interior walkthrough in Revit 2010
Wed, Aug 11, 2010 at 3:03:04 PM
Wall sweeps flipping to inside face of wall (Revit 2013)
Wed, Jul 3, 2013 at 9:13:17 PM
What is the difference Between Wall Finish Face and Wall Core Face
Fri, Oct 16, 2009 at 10:54:03 AM
Exterior walls
Sat, Jun 16, 2007 at 10:59:40 AM
Page generation time: 1.4914
