Forums >> Community >> Newbies >> Is there a typical residential (wood framing) wall family?
9 Posts No Rating |
I took a break from the tutorials to recreate a 3 bedroom farmhouse plan that I downloaded from the LSU AgCenter. I noticed that the walls are metal studs by default in Revit. Without having to duplicate and editing a type, is there a family of wood framing partitions that I can load? When I click on "Wall" the "Load Family" option is not available.
In Revit walls, the core layers are a material and thickness only definition. The core elements temselves are really not modeled. So the difference between metal stud and wood stud is only a name/thickness change and how it is represented in cut profile hatch patterns. Studs themselves are not modeled. So to create your wood stud wall, edit the type giving it a new ttpe name, modify the layer(s) thicknes amd material assignments and you have your wood stud wall.
" I took a break from the tutorials to recreate a 3 bedroom farmhouse plan that I downloaded from the LSU AgCenter. I noticed that the walls are metal studs by default in Revit. Without having to duplicate and editing a type, is there a family of wood framing partitions that I can load? When I click on "Wall" the "Load Family" option is not available. " Click Attached File
Wood Framing Walls Extension; Locating and External framing |
Wed, Apr 16, 2025 at 5:31:08 AM
wood framing extension |
Mon, May 7, 2012 at 3:23:49 PM
wood framing wall extension |
Tue, Aug 16, 2011 at 4:13:21 PM
Wood Framing - add top & bottom plates to wall family? |
Mon, Jan 19, 2009 at 12:22:01 AM
Residential Wall Types |
Sun, Mar 21, 2010 at 11:30:12 AM
Members: | 2102419 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
