74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> Croping a floorplan view in a sheet
Hi There, I'm experiencing problems by trying to crop a floor plan which is placed in a sheet. I have tryed scoped box but still the lines beyon the box itself are there. I also tryed masking region but doesnt crop lines out of region itself either.
In the view properties, turn on the Crop View and Crop Region Visible, you can now drag teh crop region to crop your floor plan. However, if you just need a certain area of a floor plan, then I would suggest using the callout tool and creating a callout of the floor plan from an overall floorplan, as it should be done. HTH.
There is a buttom called "show crop region" at the bottom (at the view) and you should be able to use that to adjust the crop area in your sheet, but i would recommend you to fix that from the view and place it back to the sheet.
Hi Rkitect, Many thanks for your wise words. Finally I've got the holy cropped plan, Regards, G.
Technical assistance floor plan details missing from view but not sheet |
Mon, Mar 6, 2017 at 9:28:02 PM
view range for floorplan views |
Tue, Sep 27, 2005 at 2:41:03 PM
Floorplan visibility in the 3D view? |
Tue, Mar 23, 2010 at 2:09:06 PM
Make annotation on wall-mounted family show on floorplan |
Wed, Nov 12, 2008 at 1:41:40 PM
what is the best "work around" for croping drafting views |
Wed, Jan 23, 2008 at 9:38:01 AM
Members: | 2017179 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
