Forums >> Revit Building >> Technical Support >> Parametric Roof Truss
7 Posts No Rating |
Hello all, I can't seem to figure out how to create one or find a parametric roof trus that has a heel to it, seems like the only ones online are without the heel (bottom cord attaches to top cord. Does anyone know any good tutorials or have a sample family that I can study to see how to create one of these, your help would be appreciated. Cheers,
I need a good challenge, got any cutsheets/pics of what you're wanting? I'll model one up for you.
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
7 Posts No Rating |
I will find a cut sheet and add it very soon. Thanks in advance for the help.
7 Posts No Rating |
Please see the attached jpg the top image shows a truss with a heel for the flow of air over the insulation and the lower picture is the typical truss that you would find on this site. Let me know how your challenge goes. Cheers,
7 Posts No Rating |
The file.
I'll sit down and work on this tonight and through the weekend, Will post as soon as I have somethign to work with. Question, are you using Revit Structure or Arch?
Edited on: Fri, Jan 14, 2011 at 9:52:08 AM
7 Posts No Rating |
We use Revit Architecture here. Thanks for taking the time to have a look at it, I'm still trying to work it out I'm close but haven't quite got it figured out yet. Thanks again, Cheers
7 Posts No Rating |
7 Posts No Rating |
Here is what I have so far, everything works great until you change the pitch of the roof, once the pitch is changed the webs do not stay tied to the top cord....any ideas?
parametric truss |
Wed, Dec 5, 2007 at 10:15:09 AM
Parametric truss taking loooong time.... |
Fri, Nov 13, 2009 at 8:59:04 AM
Can't see Truss under roof |
Tue, Feb 16, 2010 at 4:29:06 PM
Hip roof Truss |
Fri, Nov 10, 2006 at 10:18:50 AM
roof truss install |
Tue, Feb 10, 2009 at 9:00:57 PM
12
Members: | 2115345 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
