Forums >> Revit Structure >> Technical Support >> Revit 2009 Video Display Problems
Thu, Jan 13, 2011 at 12:28:39 PM | Revit 2009 Video Display Problems
clamberth6499
We have problem in complex Revit files where the display does not refresh properly and elements on the screen are not represented in the correct location until you hit F5 to refresh the display. Has this been an issue for others? We are using Revit2009 and going to Revit2011. I have a NVIDIA Quadro FX 1500 with 256MB. Do we need a card with more memory. It doesn't seem to be as bad on smaller less complex files. Has anyone had problems in 2011?
Thu, Jan 13, 2011 at 1:02:38 PM | Revit 2009 Video Display Problems
4 Stars: 201 Votes
Look this: http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=12431819
 Look at "Performance Recommendations"
better video card = better rendering? (revit architecture 2009)
Mon, Sep 29, 2008 at 9:36:49 PM
acad hatch to revit fill conversion problems (revit 2009)
Sun, Sep 21, 2008 at 9:41:31 PM
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
The video of how revit makes me mad!
Tue, Dec 30, 2008 at 7:06:48 AM
Any known problems converting projects to 2009 form 2008?
Thu, Aug 21, 2008 at 5:49:13 PM
Page generation time: 2.4270
