39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revit MEP (Modify -> View -> Line work -Line Style) question
Thu, Jan 13, 2011 at 11:02:47 AM | Revit MEP (Modify -> View -> Line work -Line Style) question
heinzk1
We are running Revit MEP 2011 and need to change the line types for Plumbing that are below slab to hidden.  Since I found out that Revit isn't smart enough to automatically choose to make the pipe hidden our plumbing designer has to manually do this.
My question as well as his is why are there line styles listed in <> and others not?
Whats the difference between <Hidden> and Hidden Lines, just to name one specific instance?
Just wondering,
Ken@rlmrlm.com
Thu, Jan 13, 2011 at 4:22:39 PM | Revit MEP (Modify -> View -> Line work -Line Style) question
rkitect
rkitect Avatar
4 Stars: 29 Votes
Response:
here is the way I understand it. <Invisible> and other similar linestyles are System Linestyles and can be edited, but not deleted. They are like that little stain in your favorite workshirt. The one that can't go away, but you continue wearing the shirt despite that. They are also special in the sense that Revit knows certain <> line styles belong to certain parts of the model automagically, <Room Seperation> and <Space Seperation> for instance. You can not define another line style to be used for Room Seperation lines, but you can modify their appearance through modifying <Room Seperation> line types. In my experience this is usually done to prevent deletion of system dependent types (ever try deleting every single wall type? One must remain!).
Question:
Are the slabs visible in your views? If so have you tried using the "Show Hidden Beyond" tool under the View Ribbon? This allows items that are hidden behind another object (ie: wall, ceiling, SLAB) to be visible via a different line type, I think <Hidden> is used by default but acn be assigned differently.
HTH.
Fri, Jan 14, 2011 at 7:59:13 AM | Revit MEP (Modify -> View -> Line work -Line Style) question
heinzk1
I dont see that setting under the View tab.  I'm running Revit MEP 2011, does it have that button?
Thanks for the Info,
Ken@rlmrlm.com
Fri, Jan 14, 2011 at 9:50:55 AM | Revit MEP (Modify -> View -> Line work -Line Style) question
rkitect
rkitect Avatar
4 Stars: 29 Votes
You are correct sir. The only other way I can think of achieving this, then, is Lineworks tool:
http://screencast.com/t/fNgB8YhMB
MEP 2010 single and Double line
Thu, Nov 12, 2009 at 2:26:14 PM
Showing Center Lines on Hidden Line graphics style
Mon, Oct 13, 2008 at 10:46:14 AM
Electrical One-Line Diagrams
Tue, Mar 10, 2009 at 2:32:19 PM
Contol Line Types and Line Weights of CAD Detials in Revit
Wed, Mar 4, 2009 at 4:54:33 AM
Object Style over rides per phases
Tue, Feb 8, 2011 at 6:17:52 PM
Page generation time: 4.2714
