61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering Help
Thu, Jan 13, 2011 at 9:36:01 AM | Rendering Help
cboersen
Rendering takes so long in Revit that it is hard to experment with different settings.  Specifically I'm wondering if I would get a better result at 75 DPI and the "BEST" setting or using 150 DPI and using the "MEDIUM" setting?  Like most people I'm trying to get the best result in the least amount of time.  I also do not understand the "uncompressed image size" information - as long as the DPI remains unchanged the size remains the same no matter what setting (from DRAFT to BEST) I render at - that does not seam logical.  Any rendering hints would be greatly appreciated.
Thu, Jan 13, 2011 at 10:22:38 AM | Rendering Help
pchan
pchan Avatar
5 Stars: 5 Votes
Have you try render the "Best" mode with the region checkbox checked?
This way you can get the higher quality with the least amount of time
Thu, Jan 13, 2011 at 12:46:47 PM | Rendering Help
cboersen
That only works if you do not want the full image rendered, right? Or am I looking at that wrong?
Thu, Jan 13, 2011 at 3:22:18 PM | Rendering Help
rkitect
rkitect Avatar
4 Stars: 29 Votes
cboersen,
Hopefully this will she a little light on what that rendering dialog is actually doing.
In regards to the Draft, Medium, High, Best settings. All this is doing is setting up the preset variables that the render engine uses, things like Daylight Portals, Anti-Aliasing, Soft shadows, etc. You can see these variable by choosing "Edit.." in the setting drop down. Things that exponentially increase render time are the settings such as the Reflection and Refraction bounce settings, Soft-Shadows, Illumination Bounces and enabling Daylight Portals. You'll notice that you can not edit the preset settings, but if you click "Copy to Custom" then you can edit them starting from the presets.
In regards to the DPI settings: obviously you understand how DPI works based ont he question you are asking so the only real answer is this; you have to look at what your final product will be viewed on. If it's jsut a screen, then 75/72DPI is all you need. If it's goign to be printed on up to 8x10, then the medium 150 dpi will most likely print better than the best 75 dpi despite the higher quality rendering. Hoever, a best 150 will look better than a medium 150 (i know render time, right).
The next question is really about what else you have in the model. Are there a lot of lights? Complex geometries? If it's really that long of a render have you tried creating a render specific model and cropping out the unecissary lights and geometries? Are you using large texture maps? All these factors come into play in time of rendering. Sometimes it's worth it, other times it's not:
 Yes, that's a 24 DAY render, but you can see the flecks in the terrazo floor. It's also a 9"x16" image at 300dpi.
HTH!
Thu, Jan 13, 2011 at 4:06:37 PM | Rendering Help
cboersen
Thank You.  Very helpful.
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:37 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:39 AM
22
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:51 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
help with rendering!
Wed, Aug 10, 2016 at 10:47:17 PM
Page generation time: 0.4170
