123 Users Online (123 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> wall joins with a linked file.
Thu, Jan 13, 2011 at 3:46:04 AM | wall joins with a linked file.
cemcem
Hello;
I have two files. One is host, the other is link. The link file contains structural model like columns, beams, floors and structural walls. The host file contains all the other data.
My problem is that i cannot join the walls with the structural walls because the structural walls are in the link. Is there a way to join normal walls to the linked structural walls?
I got two solutions:
1. To use in place void extrusions to cut the geometry from the normal walls.
2.  To create a junk workset and create little structural walls and join walls to them, then close this workset so these structural walls are invisible.
But I want a third solution that doesn't involve above solutions.
Thu, Jan 13, 2011 at 8:28:17 AM | wall joins with a linked file.
Try -  copy/monitor the structural walls and turn the structural walls off..... And I would put those on a seperate workset.
Thu, Jan 13, 2011 at 11:51:27 AM | wall joins with a linked file.
cemcem
Thanks a lot. You made my life a lot of easierSmile
Wall joins in linked files
Mon, Aug 19, 2013 at 2:58:42 PM
WALL JOINS BETWEEN LINKED rvt FILES, IMPOSSIBLE???
Wed, Aug 15, 2007 at 12:23:06 PM
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
I hate the Revit Automatic Wall joins
Thu, Oct 25, 2007 at 9:59:44 AM
Page generation time: 9.0703
