41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> if I happen to put two elevations on different sheets on the same elevation tag
Wed, Jan 12, 2011 at 2:56:34 PM | if I happen to put two elevations on different sheets on the same elevation tag
xixiha
I happen to put two elevations on different sheets on the same elevation tag, and the elevation sheet tag show as blank. warning told me to create another elevation tag. is there any way I can just detach the two I already created. Or I have to repeat the whole process, create another elevation first, and then drag that elevation on the sheet again?
Wed, Jan 12, 2011 at 3:00:58 PM | if I happen to put two elevations on different sheets on the same elevation tag
pchan
pchan Avatar
5 Stars: 5 Votes
I ran into this issue long time ago and I don't think there is a workaround on this, you will have to create a new elevation tag if you want them on seperate sheet.
Link elevation tag to another elevation tag?
Mon, Jun 11, 2007 at 2:57:41 PM
interior elevations tag question
Wed, Jun 12, 2013 at 2:00:54 PM
Want to have typical washroom elevation on multiple sheets
Fri, Oct 23, 2015 at 11:20:00 AM
Elevation tag visibility
Fri, Apr 6, 2007 at 10:32:32 AM
Missing Elevation Tag
Thu, May 7, 2015 at 7:32:03 AM
Page generation time: 5.8793
