144 Users Online (142 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Inventor files into revit
Tue, Jan 11, 2011 at 7:56:49 PM | Inventor files into revit
Nitram10
 i have a metal support piece drawn in autodesk inventor and i am wondering if anyone knows how to import it into revit.
THANKS!
Tue, Jan 11, 2011 at 10:55:42 PM | Inventor files into revit
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the ADSK format to import inventor files...
Regards,
Chris.
Tue, Jan 22, 2013 at 7:28:05 AM | Inventor files into revit
ArchVile
Im using Inventor 2012 and Revit 2013. I made a Mobile Crane in Inventor that is constrained to raise and lower the arm, rotate the arm, extend the arm, etc.. I exported it to an .adsk file and opened it in Revit through the open building component button. It opened up with a box covering it so I exploded it to get rid of the box. My question is, is the only way to move the components in my crane, is to move them in Inventor, export it, and put it back in Revit everytime i want to make a change or is there a better way to go about this?
Inventor files to revit components
Wed, Oct 12, 2011 at 8:38:25 AM
Inventor files
Thu, May 10, 2007 at 10:51:40 AM
Inventor to Revit Structure 2010 or 2011
Fri, Dec 10, 2010 at 5:45:30 AM
creating models in Inventor and exporting them into revit
Sun, Mar 6, 2011 at 4:53:22 AM
adsk files from inventor to revit
Thu, Feb 27, 2014 at 7:11:48 AM
Page generation time: 2.1946
