43 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> wall alignment
Tue, Jan 11, 2011 at 5:50:54 PM | wall alignment
passell
I'm using Revit 2011. I would like to use a model view for some details, but Face of Concrete of the stem wall aligns with the Face of Finish of the wall above. Is there an easy way to fix this, preferable in the original modeling process? I am not dimensioning to wall centerlines because it doesn't make sense for Type V construction. I coud ignore it and use drafting view for details, but it would be nice to be more precise in the model.
Tue, Jan 11, 2011 at 6:00:11 PM | wall alignment
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
very easy -- use the allign tool.  Make sure you're in a fine-detail 3d view with the section box turned on, or at least, I find that the easiest way to work.  slice through walls, and allign your face of concrete to the core.  You might have to tab a few times to get an interior plane of a wall, but that's a small price to pay.
curbed wall texture alignment
Sat, Dec 1, 2012 at 5:47:58 AM
Beam alignment problem
Wed, Mar 13, 2013 at 3:35:35 AM
Outlet & light switch alignment
Fri, May 15, 2009 at 6:54:47 PM
Draw wall alignment
Mon, Mar 31, 2014 at 12:38:30 PM
infill wall alignment to host wall
Tue, Oct 17, 2017 at 12:58:13 PM
Page generation time: 0.7371
