Forums >> Revit Building >> Technical Support >> Interior Elevations
4 Posts No Rating |
We're doing a big renovation project, and each room needs its own interior elevation. problem is - how do i change the interior elev to show not the sheet number we put it on, but the room number its placed in...? any suggestions? Thanks!
Are you asking about the view-name on the sheet? change it! If you are asking how to change the view tag - call out - why would you change it to the room number? How would you find the view?
4 Posts No Rating |
No not the view name. An elevation automatically references the sheet the elevation view is placed on. I need to change this to reference the room we placed the interior elevation in. There are 52 rooms that need to be renovated. We have A3 pages, each with a floor plan, and elevations of each room. On the main building plan we then tag the rooms, showing the room number. We simply want the elevation tags on individual room plans to reference that room number.
The elevation has no way of knowing what room it is placed in.
Create a room tag that only shows the number. Place the room tag next to the elevation tag.
----------------------------------- BallewDesigns.com |
Problem with Interior elevations |
Fri, Feb 13, 2015 at 1:51:30 PM
interior elevations |
Wed, Apr 11, 2007 at 9:43:05 AM
Interior Elevations Referencing Detail Numbers |
Sat, Oct 13, 2007 at 11:04:40 AM
Interior Elevations |
Mon, Jan 23, 2006 at 5:42:43 AM
rotating interior elevations |
Fri, Mar 17, 2017 at 6:52:26 AM
Members: | 2100980 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
