61 Users Online (60 Members):
Forums >> Revit Structure >> Technical Support >> Sloping Beam
2 Posts No Rating |
Hi there I am a newbie in Revit and this forum. Could anyone advice on how do I make a wooden beam to slope on one end please? Please see sketch attached. Many thanks in advance M
Here you go, you have control of the heights at the ends of the beam, as shown. It's just in your properties box. If you're doing some complicated geometry though, I'd suggest modeling in place, with sweeps and such. beams aren't very friendly to work with.
I guess your sketch didn't upload? If you want the whole beam to slope, either draw it in section at the desired angle or use the parameters as shown in the post above, or host the beam to a reference plane at the angle you desire If you mean you want an angled cut on the end then use a reference plane and the cut geometry tool. That is, draw a reference plane where you want it to cut, then use cut geometry tool, select the reference plane and then the beam. HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
2 Posts No Rating |
Many thanks to both of you. I should had explained more. Yes what I needed is an angled beam at the end. I will give it a go. BR M
Multi Sloping Beam System |
Fri, Mar 16, 2012 at 9:54:44 AM
sloping structural beam system - having difficulty in drawing |
Thu, Dec 30, 2021 at 10:33:02 AM
Sloping Columns |
Tue, Jan 22, 2008 at 1:45:44 PM
connecting steel beams |
Thu, Apr 8, 2010 at 9:33:24 AM
Dimensioning a Sloping Concrete Pan Joist Roof |
Sat, Feb 14, 2009 at 11:07:40 AM
Members: | 2030502 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
