47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Importing 3d cad files into Revit
Mon, Jan 10, 2011 at 10:12:41 AM | Importing 3d cad files into Revit
cabinetman23
I am just learning Revit and was wondering if I could import 3d piping into Revit MEP.  Time is very critical and I have the piping already drawn.  To save redrawing it in Revit I would like to import it in.  I will also need to run clash detection as well.  Any help?
Tue, Jan 11, 2011 at 8:11:55 AM | Importing 3d cad files into Revit
mikerthebiker
You can link it in.. but you won't be able to manipulate it at all.  Any needed changes will have to be in the CAD file and then you can 'update' the link to see the changes.  Clash detection won't work like it should because Revit Clash Detection runs interference with Revit objects (from Revit links only).
If you need to do a serious clash detection and have a Revit model for the building and MEP from CAD.. you will need NavisWorks.
NavisWorks can deal with multiple formats coming together.  For VIEWING and CLASH DETECTION.  You won't be able to design/manipulate in this environment though.
Importing CAD to REVIT (vs. 2014)
Mon, Nov 24, 2014 at 4:03:43 PM
REVIT'S POOR GRAPHIC DESPLAY WHEN IMPORTING AUTOCAD FILES
Sun, Sep 24, 2006 at 10:37:21 PM
Importing Cad Files
Tue, Mar 31, 2009 at 8:36:59 AM
Importing CAD 3D
Sat, Mar 7, 2009 at 7:26:45 AM
Importing 3D CAD Files
Tue, Apr 23, 2013 at 4:29:30 PM
Page generation time: 2.8670
