60 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Slab Edge with multiple layers
Mon, Jan 10, 2011 at 4:27:28 AM | Slab Edge with multiple layers
archie456
3 Stars: 1 Votes
Hi,
I have a building ground floor slab which comprises of 50mm Screed, 150mm Concrete, 50mm Sand, and 150mm Hardcore.
I have created a edge profile, as the slab thickens at the edge, but I cannot get this to represent more than one layer, if it prepresents the concrete it overlays all of the other layers.
Its very common to have slabs with edges made up from multiple layers - Can anyone point out to me what I am doing wrong?
Attached is a screen print of what I'm trying to acheive.
Cheers.
Sat, Feb 5, 2011 at 2:33:40 AM | Slab Edge with multiple layers
ubi1
well i have a temerorry idea, it is to add multi edge slab profile, like adding the first profile as a step, then add another new one . heince you can add material to each one.. hope this works,
Mon, Feb 7, 2011 at 2:50:29 AM | Slab Edge with multiple layers
archie456
3 Stars: 1 Votes
HI,
Thanks for your reply.
We did actually add multiple edges in the end, it works, but the its a little difficult to manage, plus you get some strange wide lines in when a section view is cut (though these are easy to change to thin lines again)
Mon, Feb 7, 2011 at 7:28:43 AM | Slab Edge with multiple layers
I usually only model the slab edge by itself.  Then I edit cut profile for the remaining when necessary.  If you really need to model these, then I suggest you seperate into seperate slabs, each with their own profile.... but why?
Mon, Feb 7, 2011 at 7:48:35 AM | Slab Edge with multiple layers
archie456
3 Stars: 1 Votes
The reason I modelled them was so that the detail drawings which cover this area look correct.
Though I now think for the hassle of getting right its easier to just draw in 2D on the detail itself.
Mon, Feb 7, 2011 at 8:43:49 AM | Slab Edge with multiple layers
If you have not yet learned to use edit cut profile, you are missing a powerful tool.
Mon, Feb 7, 2011 at 8:53:59 AM | Slab Edge with multiple layers
archie456
3 Stars: 1 Votes
I'll have to look into that - I've not used it, but assumed it was for wall junctions, not slab edges...
Tue, Feb 8, 2011 at 7:54:38 AM | Slab Edge with multiple layers
Blazarch
I think that if you only want to show each layer on the section and details, you can nest a detail component family which shows each layer into the slab edge profile family.
Blazarch is a leading CAD drafting & BIM services provider in Shanghai, China. Blazarch assists global design professionals in design and drafting of architectural, structural, HVAC, electrical, plumbing and building information modeling. Visit http://blazarch.com/ for details.
"Could not create Slab Edge"
Tue, Feb 17, 2009 at 1:40:43 PM
slab edge profiles
Fri, Oct 31, 2008 at 12:10:38 PM
RC upstand on the edge of an RC slab
Thu, Jul 14, 2011 at 11:04:57 AM
Revit 2010 Slab Edge Trouble
Mon, Feb 15, 2010 at 8:54:40 AM
Slab edge profile not available
Tue, Nov 10, 2009 at 1:56:30 PM
Page generation time: 0.5780
