119 Users Online (117 Members):
Forums >> Revit Building >> Technical Support >> revit arch 2011 - elevation and 3d views with shadows!
10 Posts No Rating |
hey, when i activate shadows on my elevations and 3d views they immediately take on a halftone appearance, its well annoying, how do i turn this (halftone appearance) off? thanks in advance, tom
Hello Tommy. If you click on the Shadow on/off button there is a Graphic Display Option... Select that. In there you will find a Cast Shadow check box with a Lighter/Darker setting that is set to 50 by default. Adjust it to your liking.
sorry i havent been very clear. i can already adjust the shadow brightness. when i activate shadows all the linework of the 3d model goes from black to grey, purely because shadows are activated and irrespective of the shadow density / brightness. it is this halftone appearance i want to control, i.e. i want my 3d models and elevations to appear to have black linework, not halftone / grey. how do i fix this? thanks againtom
I don't think you will be able to do what you want. Once shadows are turned on, the view will have to be printed as raster rather than vector.
shading and shadows in 2011 |
Fri, Dec 9, 2011 at 8:52:08 AM
any work around for this? transparent glass in shaded elevation views, revit 201 |
Mon, Jan 28, 2013 at 11:19:53 PM
Elevation Shadows |
Sun, Jun 2, 2013 at 11:46:24 PM
Revit 2011: Linked model not displaying casting shadows |
Tue, Sep 28, 2010 at 1:55:13 PM
can't see shadows on neighbours walls. |
Tue, Aug 25, 2009 at 7:35:36 AM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
