49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> roof modeling with different terrain on both face
Sun, Jan 9, 2011 at 2:26:04 PM | roof modeling with different terrain on both face
williamsham
Hi,
I need to model a roof with different terrain and slope direction on both top face and bottom face.
PART A: The top face needs to reflect drainage direction and slope.
Bottom face needs to slope with the structural beam direction. Therefore, you have different slope and terrain on both side.
If that's possible, there are several other criteria.
PART B: The roof is made of 3 layers (can be model separately as three different objects). Top most and bottom most layers have the same thickness through out. It is the middle layers that various in thickness to accomdate the two different terrain. (it is the insulation)
Please let me know even if you have solution for only one of the parts.
Mon, Jan 10, 2011 at 1:37:03 AM | roof modeling with different terrain on both face
KMunkholm
Variable thickess of roof layers only work for flat roofs, so there´s no easy way to get what you want.
 If you really need to model the drainage directions, I´d suggest that you create a facebased family for the wedge insulation. Good luck.
-Munkholm
www.revitforum.org
revit terrain and roads
Wed, Jul 25, 2012 at 2:19:59 AM
Modeling a curved sloped roof
Tue, Mar 14, 2017 at 7:04:15 AM
Roof by Face and Wall by face tools
Tue, Jan 28, 2014 at 6:31:04 AM
Pathway on a curved green roof
Fri, May 3, 2013 at 2:08:35 PM
Roof by face, wall by face clean up
Tue, May 29, 2012 at 4:57:44 AM
Page generation time: 0.6337
