79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> slab thickening below hardcore
Fri, Jan 7, 2011 at 10:03:18 AM | slab thickening below hardcore
iangus
small niggle follows:
floor construction say 150mm concrete slab on 150 hardcore layer with the concrete slab having an edge thickening. once a section has been cut the thickening positions itself to the hardcore rather than the concrete slab. although the thickening can be moved with an offset the hardcore runs straight through the upstand (boo). i can manually cut out the hardcore on the sections but this all seems rather manual/a fudge. any bright ideas from any bright sparks?
Fri, Jan 7, 2011 at 10:12:46 AM | slab thickening below hardcore
Wow - you made me smile.  Trying to understand your slang (terminology) - I hope someone else from GB can answer this because I don't understand words like niggle (problem?) hardcore ? (don't have a clue) upstand (boo) ... << what :->
I am assuming that your floor is multilayer with the hardcore being something like gravel?
Maybe you will have to split this into slab and hardcore as two seperate elements?
Fri, Jan 7, 2011 at 10:45:44 AM | slab thickening below hardcore
iangus
niggle - problem. spot on
hardcore - hardcore (stone)
boo - rubbish/bad/crap
Fri, Jan 7, 2011 at 10:51:18 AM | slab thickening below hardcore
matthewh75
3 Stars: 3 Votes
I know exactly what you mean! Smile
I think the best way to sort this out is to do as WWHub says (& BTW WWH you're not incorrect in your slang interpretation!) lay you 150mm floor with it's build up as 75mm screed, 75mm insulation, 150mm concrete as one floor, apply the slab edge to this floor. You can lay another 'hardcore/gravel' layer under the floor just created using the floor tool, then model the angled section as a sweep. Use 'join geometry' to merge sweep & floor
You could try pads, but they're rubbish at angles
Fri, Jan 7, 2011 at 10:55:39 AM | slab thickening below hardcore
matthewh75
3 Stars: 3 Votes
You may have to hide the sweep in plan views however, but you do get away without all the 'edit cut profile' manual stuff
Wed, Jan 12, 2011 at 5:02:03 AM | slab thickening below hardcore
iangus
thanks for that mathewh75. perhaps as im not having to do any takeoff/quants for the hardcore then having 2 floor buildups might be a little OTT especially if any voids/lift shafts etc move around. maybe in this case it might be that i just create a filled region on the sections - then again id have to edit the filled regions if something changed in anycase. swings and roundabouts i suppose
Wed, Jan 12, 2011 at 5:26:21 AM | slab thickening below hardcore
matthewh75
3 Stars: 3 Votes
You can lock the floor sketch lines to the lift shaft walls, and the sweep lines & paths to the toe of the foundations allowing them to flex together, personally i think it's worth spending the time doing the little work involved in setting up the 2 floors as potentially editing all the layers in the floor for each section at the toe junctions is a right pain in the backside. Unless someone else can tell me a different way to do it?
Thickening slab edges.
Thu, Jul 3, 2008 at 3:19:18 PM
Mid slab foundation thickening
Tue, Jul 31, 2012 at 7:58:11 AM
Adding Reinforcement to a Custom Slab Thickening Family
Fri, Apr 30, 2010 at 12:27:08 AM
Hidden line Help!!! Please!
Wed, Sep 19, 2007 at 2:56:12 PM
Slab Edge with multiple layers
Tue, Feb 8, 2011 at 7:54:37 AM
Page generation time: 0.2815
