102 Users Online (101 Members):
Forums >> Revit Building >> Tips & Tricks >> damp proof membrane in section
9 Posts No Rating |
ok ive a floor construction basically nothing but say 150mm concrete sat on a dpm. when cutting sections traditionally in autocad the dpm would show as a dashed line. is this possible in revit? (without just adding a dashed detail line).
Sorry no - we add the dashed lines.
![4.5 Stars: 2 Votes](/images/stars_4.5.gif) |
You could add a substrate layer about an 1" thick and then use the linework tool to change the bottom line to a dashed line and the interior line to a darker cut line.
11 Posts No Rating |
Maybe add a layer to floor structure, then linetype tool as needed?!
Check out RevitTube for Awesome Revit Videos Daily - https://www.youtube.com/channel/UCl-rjEtxDTE0DOrtqOV8aKw |
What's the Point of the Membrane Layer |
Mon, Nov 11, 2013 at 5:11:55 PM
Tensile Membrane Structures [ 1 2 ] |
Fri, Oct 1, 2004 at 10:43:14 AM
21
Errors using Membrane Layer: zero / non-zero thickness |
Wed, Aug 7, 2013 at 6:08:50 PM
Kenoting a Membrane Layer (0" thickness) |
Sat, Feb 12, 2011 at 12:23:27 PM
Displaying membrane layers as dashed lines in detail view |
Mon, Jun 9, 2008 at 3:43:11 PM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
