44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Moving Levels - Annotation only
Fri, Jan 7, 2011 at 5:36:09 AM | Moving Levels - Annotation only
mhoare
Hi
I am relatively new to Revit - this is my first forum post.
I have a built a Revit model for which I set up all the levels at the start. The level symbols are sitting on top of the building in some of my elevation views. I would like to move them of to the side without affecting anything in my model. i.e just move the symbols. At the moment I am getting a series of error warnings such as "Can't Make Wall", "Can't keep elements joined" and "Highlighted walls overlap". I understand that parts of the model components etc are attached to specific levels, but I was wondering if there is a quick way to move only the graphical symbols.
Can anyone help?
Fri, Jan 7, 2011 at 7:34:05 AM | Moving Levels - Annotation only
select the label and near the tag, you will see a small circle grip.  You can grab that grip and move it left or right.
You should read more about levels in your Help so that you understand how to control their visual representation in your vieews.  The information is all in your HELP and is well documented.  If you learn to use that, you will be well rewarded.
Moving Floor Levels Independently
Thu, Feb 25, 2010 at 1:37:18 PM
Moving Annotation Symbols without moving objects
Mon, May 23, 2011 at 6:39:44 PM
How do you reassociate elements to other levels without them moving???
Sat, Sep 23, 2017 at 9:30:18 AM
11
Moving up Multiple Tower Levels
Thu, Feb 17, 2011 at 3:55:02 PM
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:47 AM
Page generation time: 0.4620
