Forums >> Revit Building >> Technical Support >> Sloped Grade Beam in Foundation Plan
Thu, Jan 6, 2011 at 6:39:46 PM | Sloped Grade Beam in Foundation Plan
huong
How can I draw the sloped Grade Beam in Foundation Plan ? We only have the staight grade beam in library.
Can I use the sweep ?
   Thanks,
Huong
Thu, Jan 6, 2011 at 8:40:32 PM | Sloped Grade Beam in Foundation Plan
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Beams are workplane based, so create a reference plane at the slope you want to draw you beam at and set that as the host, or draw the beam in a section or elevation view.  Alternatively, model a foundation slab and add a slope arrow to define the slope.
HTH.
Regards,
Chris.
Sloped terrain and sloped foundation wall
Thu, Sep 3, 2009 at 1:57:36 PM
Pier caps in Grade beams
Mon, Aug 29, 2011 at 2:01:13 PM
Stepping foundation wall to follow grade
Fri, Nov 9, 2007 at 1:57:53 PM
foundation
Tue, Jul 17, 2018 at 10:41:10 AM
Sloped Beam?
Thu, Dec 15, 2005 at 3:38:36 PM
Page generation time: 0.6245
