49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> vertical wood siding wall?
Thu, Jan 6, 2011 at 3:54:22 PM | vertical wood siding wall?
rkowalski
I am interested what is the easiest way to make such wall
 I want to have graphical representation in facade views mostly
Wall detail view would be nice but isnt necesarry
but if it's easy enough - any tips on making such wall would be great (second picture)
Fri, Jan 7, 2011 at 10:00:38 AM | vertical wood siding wall?
matthewh75
3 Stars: 3 Votes
Set the material you specify for the external wall as a vertical wood board, with a surface hatch as vertical lines, this should take care of the elevations. Use repeated details of the battens, counter battens & boarding in plan/section
Wood Siding
Fri, Nov 22, 2019 at 3:17:58 PM
11
Vertical line in exterior rendering
Thu, Feb 23, 2006 at 3:29:25 PM
rendering horizontal wood siding.
Wed, Aug 5, 2009 at 10:49:00 AM
How do i add wood siding in the exterior wall? Need major help!
Tue, May 15, 2018 at 9:57:18 AM
revit 2015-exterior elevations horizontal lines of wood siding
Sun, Dec 6, 2015 at 10:01:16 PM
Page generation time: 2.7488
