136 Users Online (135 Members):
Forums >> Revit Building >> Technical Support >> Fill pattens below pads
2 Posts No Rating |
Can someone help me understand why my plans will display a void under a pad. I have a building cut into the topography. the lowest level is smaller in plan than the level at grade. At the 1st floor( lowest level) plan the earth fill pattern from the topography is present except where the upper level footprint is extended, in these areas it is blank. phase filter is set to display show all. in section the areas under these pads appear do not highlight when i select the rest of the topography Drawing an filled region is not acceptable solution.
Have you tried the paint bucket to paint the surface?
2 Posts No Rating |
there doesn't seem to be anything there to paint.
CUT AND FILL - PADS WHICH DO NOT SHOW C&F VOLUME ON A SCHEDULE |
Tue, Feb 13, 2018 at 4:37:06 AM
Revit Cut and Fill |
Thu, Jan 13, 2011 at 5:02:33 PM
CUT AND FILL |
Tue, Dec 9, 2008 at 5:31:09 PM
Scheduling cut and fill when using split regions |
Sun, Sep 21, 2008 at 8:56:58 AM
Topography and pads trick |
Mon, Jan 14, 2013 at 2:53:18 PM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
