52 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Mass Project Parameter creation
43 Posts No Rating |
guys, is there a way of batch importing/creating shared parameters for rooms, instead if one by one say for illuminance etc?? got a shed load to import and create was looking for a quick way of doing it but i fear there isnt!! architecture 2010 by the way
28 Posts No Rating |
First, open the project you are trying to import parameters INTO, then open a project file that has all of the parameters you need to import. Switch your window back to the target project and go to Manage/Transfer Project Standards (Not positive that this exists in 2010, but it is in 2011), make sure the drop down menu shows the project that contains your needed parameters, click on project parameters and hit OK. I think that should accomplish what you are trying to do.
----------------------------------- The Leffler Group |
ok, so the transfer is possible after initially entering all the parameters into an exisitng model, theres no way to batch import form a shared parameter file??
Add them to your template.
yeaas, i will from now, just means creating 25-30 seperate project parameters lol was being lazy hoping i could do it in one go no worries, they are in now and in the template for future use etc
mass, edge creation r2011 |
Fri, Oct 29, 2010 at 6:37:04 PM
adding mass in family editor or in place family creation |
Thu, Nov 23, 2006 at 9:52:52 AM
Conceptual Mass Project Space Visibility |
Fri, Jul 15, 2011 at 1:46:11 PM
Unable to load conceptual mass into project |
Fri, Sep 11, 2015 at 1:40:26 PM
Using mass in more than one project |
Tue, Nov 28, 2006 at 2:19:12 PM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
