Forums >> Revit Building >> Technical Support >> How to remove a Wall Sweep
160 Posts No Rating |
I am using Revit 2010 This seems like a simple task to me but I cannot seem to find the answer. I have used a standard wall sweep and now want to remove it, but I can't. The new "reveals" highlight when one mouse's over them & one can delete them from there, but the sweep highlights with the wall & I cannot see where to delete them.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
Is this an intergral sweep with the wall. if that is the case, the only way you can delete it is to delete from the type property of the wall. Go to edit new--> Edit from the structure parameter -->click sweeps --> then delete the wall sweep from the table. be careful when doing this, it removes all the wall sweep from the same wall type HTH
thx pchan, that worked, is there another way to just put a sweep on say one wall. Like is it possible to use a mass object to do the job??
Cheers Dermot
www.dmbd.net |
You can use host sweep under the wall tab and make a duplicate from the default style and choose another profile family from the project (or you can load a new one from the library). this way, you can create either horizotal or vertical sweep on your wall Phil
Remove Wall Sweep Types |
Fri, Feb 20, 2015 at 1:33:23 PM
Wall Sweep Missing at Infill |
Tue, Mar 6, 2012 at 2:06:40 PM
Wall sweep won't trim |
Tue, Apr 25, 2017 at 2:07:18 PM
Wall Sweep Doesn't Completely cut |
Tue, Jun 19, 2018 at 10:47:02 AM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ] |
Sun, Dec 7, 2008 at 3:51:45 PM
19
Members: | 2115633 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
